Need help with PIC16F676
Discussion in 'Electronic Basics' started by uuuuu, Aug 18, 2003.
  1. uuuuu
    uuuuu Guest
    I want to switch on PORTA pins RA4 & RA5 but the problem is that pin RA2
    seems to go on as well (by on I mean low). Attached my code, I was
    wondering if anyone can help to find the problem. BTW I have 3 warnings
    when compiling that the wrong bank is selected, why am I getting these
    warnings, I used the BANKSEL macro ?
    Tia.
    list p=16F676 ; list directive to define processor
    #include <p16f676.inc> ; processor specific variable definitions
    __CONFIG _CP_OFF & _WDT_OFF & _BODEN & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _CPD_OFF
    ;Defines
    #define Bank0 0x00
    #define Bank1 0x80
    ;Reset Vector
    ORG 0x000 ; processor reset vector
    nop ; required by in circuit debugger
    goto Init ; go to beginning of program
    ;Interrupt Vector
    ORG 0x004
    return ; interrupt trap - returns without re-enabling
    ;Initialization
    Init
    ;call 0x3FF ; retrieve factory calibration value
    ; comment instruction if using simulator, ICD2, or ICE2000
    BANKSEL Bank1 ; BANK1
    movwf OSCCAL ; update register with factory cal value
    movlw B'00000000' ;
    movwf TRISA ;
    clrf ANSEL ; configure A/D I/O as digital
    banksel Bank0 ; change back to PORT memory bank
    movlw CM2 | CM1 | CM0 ; configure comparator inputs as digital I/O
    movwf CMCON ;
    ;Main
    Main
    movlw B'11001111' ; RA4, RA5 will be low (= on in my circuit)
    movwf PORTA
    main1
    goto main1
    ;Subroutines & Functions
    END ; directive 'end of program'
  2. Guest
    Guest Guest
  3. Guest
    Guest Guest
  4. strill
    strill Guest
    Hi Tia
    This may be redundant but try putting a BANKSEL macro at the beginning of
    init.
    The assembler/PIC may be defaulting to the wrong bank.
    Strill
  5. uuuuu
    uuuuu Guest
    Hi Tia
    The bank select command was there, where were you looking ?
    I'll simplify it:
    To set RA2 as an output pin with low output what do I do?
    Here is what I did (but it did not work as RA2 stayed high all the time)
    BANKSEL Bank1
    bsf TRISA,2
    clrf ANSEL
    banksel Bank0
    movwf CMCON
    bcf PORTA,2 ; set output low
    Thanks.
  6. Guest
    BANKSEL expects a label taken from somewhere in your code. That
    "somewhere" is then examined to discover which bank it happens to be
    in (it could vary as your code grows longer). Then, and only then,
    will the compiler decide what instruction(s) to use for selecting the
    correct bank and these will replace "BANKSEL <variable>". (section
    5.6, page 40 of MPASM user's guide)
    My guess is that you need to do something like this:-
    BANKSEL TRISA
    to keep the compiler happy.
    should be
    bcf TRISA,2
    to set to output
    Cheers
    Robin
  7. Charles Jean
    Charles Jean Guest
    Ater configuration word and before variable and constant declarations
    put:
    errorlevel -302
    this will suppress the warnings you are getting for bank selections
    a quirk, I quess, with MPASM
    What a way to run a railroad!!!
    If God hadn't intended us to eat animals,
    He wouldn't have made them out of MEAT! - John Cleese
