Need help with loop
Discussion in 'Microcontrollers, Programming and IoT' started by Joshsinclair, Jul 7, 2015.
  1. Joshsinclair
    Joshsinclair
    3
    Feb 28, 2015
    Hi
    Im having trouble writing code for a adc loop.
    What the program needs to do is update the display when the ADC value changes, Currently it is set up so every 200ms the loop restarts, reads the adc value and updates the display.
    The reason im wanting to change this is so the lcd only rewrites the value when it changes. currently the lcd flickers because it is clearing the lcd and rewriting the same value every 200ms.
    this is my current loop written in Mikroc for pic
    Code:
    //Variables
    float A = 1000.0;
    float B = 1001.0;
    float C = 1002.0;
    float D = 1003.0;
    flaot E = 1004.0;
    char Txt[15];
    //loop
    While (1){
    E = ADC_Read(2);
    D = A * ((E - B) / (C - B));
    InttoStr(D, Txt);
    Lcd_Cmd(_LCD_CLEAR);
    Lcd_Cmd(_LCD_CURSOR_OFF);
    Lcd_Out(1,1,Txt);
    Delay_ms(200);
    Thanks Josh
  2. Harald Kapp
    10,025
    2,138
    Josh,
    I took the liberty to put the code into a code-box for better readability.
    Your choice of variable names (A, B, C, D etc.) is sub-optimal :rolleyes:. Nobody but you can decipher what D=A*((E-B)/(C-B)) is doing.
    Back to the question:
    Use an additional variable to store the result of the previous ADC reading. Output only if the new reading differs from the old reading:
    Code:
    old_ADC=0;
    While (1){
    E = ADC_Read(2);
    if (old_ADC != E) // only if the new reading differs from the old reading
       InttoStr(D, Txt);
       Lcd_Out(1,1,Txt);
       old_ADC = E; // set the old reading to the new reading to prepare for the next pass
    Delay_ms(200);
    Regards,
    Harald
