Need help with component identification
Discussion in 'Datasheets, Manuals and Component Identification' started by rfenergy, Nov 20, 2013.
  1. rfenergy
    rfenergy
    Nov 20, 2013
    Greetings. I am in desperate need of some help identifying this part. It is out of a DC power supply and is near a full wave bridge rectifier section. The identification on the PCB is labled as "TH1," so I'm thinking it's a two lead thyristor of some sort? Markings appear in three lines and are as follows "OS, 080, 24" It is dark green in color. Any help anyone can give would be greatly appriciated. I do not have the schematic or parts list for this unit. (picture attached)
  2. (*steve*)
    25,482
    2,830
    That looks like a thermistor (A thyristor would likely be "Q" or possibly "D" not "TH"). (A 2 terminal thyristor is called a diac and is often grouped with diodes)
    It doesn't look damaged. Do you think it is?
    What value of resistance does it have?
    If you warm it between your fingers does the resistance go up or does it go down? (Alternatively it may not change)
  3. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    I'll submit my guess:
    Just the physical construction, and the fact that it's in a power supply, makes me
    think it could be a varistor. Designed to absorb transient voltage spikes.
    It's rare to see a cap with the leads so prominently tied to the sides of the device.
    It LOOKS to me, like the physical construction of a varistor.
