need help with calculation.
Discussion in 'General Electronics Discussion' started by needy, Sep 27, 2009.
  1. needy
    needy
    4
    Aug 13, 2009
    hi guys i'm stuck on two calculations i kind of have an idea but not exactly sure and would love to find how to calculate the following
    Q1. Two resistors R1 and R2 are are parralel connected to a voltage source. If R1 has a value of 50ohms and and a current of 2.0 amps
    1 . what is the voltage across R2? = is it 100v
    2. and is the supply voltage 100v?
    Q2. A series circuit has three resistors, if the voltage across R1 is 4volts, R2 is 5volts and R3 is 6 volts
    1. The circuit voltage is 10 volts, correct?
    2. what (or how do i find) the resistance value of R2 if R1 has 2.0 amperes flowing through it?
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Q1: U=I*R, 2*50=100, Parallell=same voltage.
    Q2: How do you figure 10V? 4+5+6=15, Series=same current, R=U/I, R2=5/2=2.5 ohms.
