Need help with a multiplexer
Discussion in 'Electronics Homework Help' started by Stoneww, Feb 28, 2020.
  1. Stoneww
    Stoneww
    42
    Apr 18, 2017
    Hey,
    I have a project and I want to use a multiplexer to periodically switch between 5 different inputs (analog) to be output one by one, the output will be fed to a microcontroller. The same microcontroller is used to signal which input should be output.
    NOTE: the voltages read by the mux will be between 0 V and 5 V.
    I assumed that the multiplexer has to be one that is labelled as "analog" due to the type of inputs I am using.
    I wanted to use the DG408, however I have a 9 V power supply and the data sheet specifies that one of the pins needs to be connected to "V-". I'm wondering if it would be okay to leave that pin either not connected or grounded and only use "V+" and "GND" to power the component?
    If not, can someone suggest a multiplexer I can use to achieve this? I'm struggling to find one.
    King regards.
    DG408 Datasheet:
    https://www.renesas.com/us/en/www/doc/datasheet/dg408-09.pdf
  2. bertus
    bertus Moderator
    1,864
    707
    Nov 8, 2019
  3. Stoneww
    Stoneww
    42
    Apr 18, 2017
    TCRT 5000 sensors, they will output between 0 and 5 volts.
  4. Stoneww
    Stoneww
    42
    Apr 18, 2017
    Also that one requires VDD, VEE and VCC. And with a battery powered I can't really provide negative voltage.
  5. bertus
    bertus Moderator
    1,864
    707
    Nov 8, 2019
    Hello,
    That should not be a problem.
    The datasheet shows these schematics:
    Perhaps the same can be done with the DG408.
    Bertus
  6. Stoneww
    Stoneww
    42
    Apr 18, 2017
    Ye looks good, you think this can also be the case for the MUX I used?
  7. bertus
    bertus Moderator
    1,864
    707
    Nov 8, 2019
    Hello,
    Reading the datasheet, the powersupply may be single ended:
    Bertus
    Stoneww likes this.
  8. Stoneww
    Stoneww
    42
    Apr 18, 2017
    Okay thanks, I think Will switch to the one you first suggested
