Need Help with a motor control
brian haffke
Jul 10, 2017
Jul 10, 2017
I need help what I need is for a motor control when a line goes up and closes a limit switch it would allow the motor to run 3 seconds even after the limit switch is open this would allow the line to be loose and as it pulls up again same thing
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Your description of the circuit operation is a bit vague, (not helped by the lack of punctuation making the current description difficult to understand) and our advice is given based on the detailing of the question... however what I think you're asking is as follows:
Use a 3 second non-retriggerable monostable who's output is used to momentarily short the limit switch for the 3-second period you require.
Google 555 monostable for suitable circuits. Use the 555 output to drive a relay where the contacts of the relay are wired across the existing limit switch.
