Hi all,
I am having trouble getting outputs to work properly with a 16F88.
Everything works as expected when using the debugger but when I run the program by itself the outputs are not activating high.
I have tried pulling up MCLR to VCC though a 10K resistor but that did not help. I have tried setting MCLRE both ON and OFF as well.
__CONFIG(WDTE_OFF & MCLRE_ON & CP_OFF & BOREN_OFF & FOSC_INTOSCCLK & PWRTE_OFF & LVP_OFF);
INTCON = 0x0; // Disable interupt
CMCON = 0x7; // Comparators OFF
ANSEL = 0x00; //set digital inputs
ADCON0 = 0x00;
ADCON1 = 0x00;
//enable weak pullups on portB
nRBPU = 0;
TRISB6 = 0;
TRISA3 = 0;
TRISA2 = 0;
TRISA1 = 0;
TRISA0 = 0;
do {
PORTA = 0x00;
__delay_ms(1000);
PORTA = 0xFF;
__delay_ms(1000);
} while(1);
All outputs alternate high and low (LED's flash) when running with the debugger but they do not light at all when not running in the debugger.
Any ideas?
ADCON0 = 0x00;
ADCON1 = 0x00;
nRBPU = 0;
TRISB6 = 0;
TRISA3 = 0;
TRISA2 = 0;
TRISA1 = 0;
TRISA0 = 0;
do {
PORTA = 0x00;
__delay_ms(1000);
PORTA = 0xFF;
__delay_ms(1000);
} while(1);
Any ideas?
