Need help wiring a dc motor to cycle forward then reverse
Discussion in 'Sensors and Actuators' started by licata59, Jan 26, 2013.
  1. licata59
    licata59
    Jan 26, 2013
    Hello,
    I need help wiring a dc motor forward then reverse. My idea is to have a motor pulley raise then lower a cycle. I have tried a dpdt toggle switch mounted to the line so that when the motor moves the line it hits the switch and hopefully would trigger it to change direction.. but unfortunately it just moves the switch to the in-between state turning off the motor. Anyone suggest anything different? different switches? set up?
    also I was wondering about the motor and the amperage. I got it from here,
    and have thttp://www.goldmine-elec-products.com/prodinfo.asp?number=G17949
    It works well with a 6v 500ma plug but wanted to know about any other plugs to make it more powerful or faster without burning it out.
    Thanks.
    David.
  2. Timescope
    Timescope
    43
    Aug 30, 2012
    I posted a circuit that would reverse a motor in this thread https://www.electronicspoint.com/motor-reversing-relay-t255878.html
    You could use a 555 timer to drive the "direction" input . Connect limit switches to the "trigger" and "threshold" as shown in attached image. The 1k resistor is for protection in case both switches are on together.
    Timescope
