Need Help w/Littlefuse Ratings, Please
Discussion in 'Electronic Repair' started by Marvin Moss, Aug 31, 2003.
  1. Marvin Moss
    Marvin Moss Guest
    I need some 3AG Slo-Blo fuses rated at 8 amperes.
    I have some but they say 313 3AG 8A 32V on the end cap.
    I need some that will function at 120VAC. Will these work OK at 120VAC or
    is there the possibility they will arc internally and not open cleanly?
    What do I need that will work at 120VAC?
    TIA,
    Marvin
  2. Marvin Moss
    Marvin Moss Guest
    BTW The Littelfuse datasheet says 8A is 250V and 10A is 32V. I have asked
    Littelfuse about this discrepancy between the fuse and the datasheet.
  3. WItam40231
    WItam40231 Guest
    The voltage rating on the fuse is the highest voltage that the fuse can handle
    without shattering the glass or shorting internally.
