Need Help w/ Custom Portable Speaker Schematic
Discussion in 'General Electronics Discussion' started by Extra Syrup, Sep 29, 2015.
  1. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    Hi! I'm planning to build a custom portable speaker. I am hand crafting the casing from wood, and I know how I want it to look and operate, but I do not have the knowledge to design the schematic. Is anyone interested in working with me to create the schematic?
    To give you an idea, here is the basic premise of the component setup:
    There will be four 3 inch speakers housed in a wooden cube. There will be one 3.5mm aux jack. There will be a power switch and an LED light. It will run off of battery power that will also be inside the cube. The type of batteries used are yet to be determined.
    It seems like a fairly simple schematic for an experienced person. Anyone interested in lending a hand?
    Thanks very much! :)
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Hello
    One important question, what are the wattage and impedance of the speakers you plan to use?
    Adam
  3. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Now do you want the enjoyment of building a circuit or are you happy to have a module.
    Adam
  5. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    I'd definitely like to appreciate building a circuit from start to finish. Plus, whatever I put together has to fit within the 4 to 5 inch cube that will house it. Each speaker will be mounted on each of the 4 sides around the horizon of the cube.
  6. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    Also, I will mostly likely want to use an on/off push button switch.
  7. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
  8. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
  9. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    I'm sorry, Adam, but you have lost me with this. I am just looking for help or advice on getting the circuit schematic put together so I can build it myself. I can do basic circuity work, but I am not good at planning the circuit design. I appreciate your assistance so far.
  10. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    The schematic is in the datasheets I sent you with all the other components. I don't quite understand your response.
    Adam
  11. Bluejets
    Bluejets
    4,748
    999
    Oct 5, 2014
  12. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    I apologize. I do see the various schematics, but none of them seem to exactly match my particular situation. I'm a super noob, so I just need a little more hand holding. ;)
  13. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    Good point! I will certainly incorporate this into my design. Thanks! :)
  14. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Please elaborate on your situation? I don't understand.
    Adam
  15. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    I'm essentially looking for someone who knows circuitry well enough to put the schematic together based on the components that I know I want to use. Four 3 inch speakers, 1 power switch, an LED (power indicator), and a battery. As to any other components needed to tie all of that together, I look to the expert for the inclusion of those components into the schematic.
    If I'm not making sense or this sounds ridiculous, just let me know. Haha :)
  16. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Well the main component Martin is the amplifier. You will need those components first and you build the circuit and attach the speakers to the output, being they are the same you could have two parallel lots of two in series giving you 8 Ohms. Although the amplifier can drive much lower impedances I would stick to 8 Ohms.
    Adam
  17. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Sorry I just called you Martin for some reason :confused:, I am tired, I am off to bed!
    Adam
  18. Martaine2005
    Martaine2005
    3,411
    926
    May 12, 2015
    Is this of any use to you?
    It's made from readily available modules.
    [​IMG]
    Martin
  19. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    Thanks for the explanation! :)
  20. Extra Syrup
    Extra Syrup
    11
    Sep 29, 2015
    This helps, thanks for including! I think I'll be leaving out the woofer part since it's just a small portable box that I'm building.
