Need Help - VCO
Discussion in 'General Electronics Discussion' started by Mini, Jun 21, 2013.
  1. Mini
    Mini
    18
    Jun 8, 2013
    Hi, guys
    It is a Voltage-controlled oscillator (VCO). Αn oscillator that its frequency is controlled using a voltage signal. The VCO described here provide both triangular and square wave output. The control voltage can be varied between 5 mV to 5 V, to produce oscillation frequency from 10 Hz to 10 KHz.
    Would u plz explain the operation of the circuit to me briefly ?
    Thanks advance.:confused:
      File size:
      23.4 KB
      155
  2. davenn
    davenn Moderator
    13,833
    1,950
    this identical question and image was posted a few days ago in this thread
    go read it ... and next time search the forums before you post the same question again
  3. Mini
    Mini
    18
    Jun 8, 2013
    OK.. i will try ... thanks.
