Need help to find an equivalent SMD.
Discussion in 'Datasheets, Manuals and Component Identification' started by QTechy#7, Oct 11, 2019.
  1. QTechy#7
    QTechy#7
    Oct 5, 2019
    Hi, I need help to identify a burnt out SMD component located on M801 position with code marking 28 and can be depicted
    inverted written 20 and finally might be the letter "t" (attached photos). I would like to find an equivalent SMD
    as I intend to replace the damaged component. It belongs to Philips BG2024/15 which I intended to replace the two rechargeable
    batteries, but somehow it got burnt out when touching accidentally inverted polarity from new 2 1.2v NiMH battery pack.
  2. davenn
    davenn Moderator
    13,552
    1,850
    hi, I have edited your post a bit to make it more readable
    Looks like you whacked it hard with a screwdriver or soldering iron tip
    I have had a look for that number in SMD pages online not found yet with those markings
    someone else may be able to find it ?
  3. WHONOES
    WHONOES
    854
    206
    May 20, 2017
