need help to display on LCD
Discussion in 'Microcontrollers, Programming and IoT' started by kingrosekhan123, Apr 15, 2013.
  1. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    hello..
    i am using PIC 18f458
    please help me..i write code for capture to measure period of pulse.
    but i dont know how to display it on LCD.
    kindly help me in code..to display.
    Code:
    CCP1CON=Ox05; I /Capture mode on every rising edge
    T3CON=0x00; //Timerl for capture
    TlCON=0x00; //Timerl internal elk, 1:1 prescaler
    TRISB=0; //make PORTE output port
    TRISD=0; //make PORTD output port
    TRISCbits.TRISC2=1; //make CCPl pin an input
    CCPR1L=0; //CCPRlL = 0
    CCPR1H=0; //CCPRlH = 0
    while (1)
    TMRlH=0;
    TMRlL=0;
    //clear Timerl
    PIR1bits.CCP1IF=0; //clear CCPliF flag
    while (PIRlbits. CCP1IF==0); I /wait for 1st rising edge
    TlCONbits.TMRlON=1; //start Timerl
    PIRlbits.CCP1IF=0; //clear CCPIF for next edge
    while (PIR1bits. CCP1IF==0) ; I /wait for 2nd rising edge
    T1CONbits.TMR1ON=0; //stop Timerl
    PORTB=CCPR1L;
    PORTD=CCPR1H;
    i'm new to this fourm.
    waiting for good responce.
    Thanks..
  2. BobK
    7,682
    1,688
    Your C compiler library probably has code to drive LCD displays.
    If not, Google will find many variants of it.
  3. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    i mean that...here is to calculate period of pulse..
    but may changes will appear on lcd display.
    for example ..if i change freq. then it must vary on LCD..there should be a formula that is associated with LCD.
    i.e made changes in value on LCD at that spot..
  4. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    where is discussion???
    if you need to google each item..what is benefit of fourms..????
  5. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    Code:
    #include <htc.h>
    #define RS RA0
    #define EN RA1
    #define _XTAL_FREQ 4000000
    //prototypes
    void display(char fig);
    void init(void);
    void main(void);
    void clock(void);
    void clear(void);
    __CONFIG(MCLRDIS & WDTDIS & UNPROTECT & LVPDIS & INTCLK);
    unsigned char d1,d2,d3,d4,d5,d6,d7;
    void init(void){
    	CMCON = 0b00000111;		//comparator off
    	T1CON = 0b1110;        //TMR1 prescale 1:1, osc=on
    	TRISB = 0b11000000;		 //RB 4 bits data output
    	TRISA = 0b11110000;
    	OPTION = 0b10100000;	//TMR1 pre=1:2
    	//LCD init, LCD module is preset for 8 bits data so we need to set it for 4 bits mode.
    	__delay_ms(100);
    	PORTA=0;
    	PORTB=2; clock();	//4 bits mode
    	PORTB=2; clock();	//function set: 4 bit
    	PORTB=0; clock();	//function set: 1 line
    	PORTB=0; clock();	//display set:
    	PORTB=12; clock();	//display set: curzor off
    	PORTB=0; clock();	//Entry mode:
    	PORTB=6; clock();	//Entry mode:increment address
    void main(void){
    	unsigned long total;
    	unsigned int freq2;
    	unsigned char freq1,nz;
    	init();
    for(;;){
    	freq1 = 0;
    	freq2 = 0;
    	TMR1L = 0;
    	TMR1H = 0;
    	TMR1IF = 0;
    	nz=0;			//no zero flag
    	TMR1ON = 1;		// open gate
    	TMR0 = 0;		// start count
    	T0IF=0;
    	while (!TMR1IF){		//loop for 2 seconds
    		if (T0IF){++freq2; T0IF=0;}
    	freq1=TMR0;		//stop count=copy reg
    	TMR1ON = 0;		//close gate
    	total=(unsigned long)freq1 + (unsigned long)freq2 * 256; //sum up the 2 reg
    	       //convert binary to 7 decimal digits
    	d7=total/1000000+48;		//1MHz digit
    	d6=(total/100000) %10+48;	//100KHz digit
    	d5=(total/10000) %10+48;
    	d4=(total/1000) %10+48;
    	d3=(total/100) %10+48;
    	d2=(total/10) %10+48;		//10Hz digit
    	d1=total %10+48;
    	clear();		//clear LCD
    	display(32);	//blank
    			//remove leading zeros from first 4 digits
    	if(d7 == 48){display(32); display(32);}
    		else{display(d7); display(44); nz=1;}	 //44=,
    	if(d6 == 48 && nz==0){display(32);}
    		else{display(d6); nz=1;}
    	if(d5 == 48 && nz==0){display(32);}
    		else{display(d5); nz=1;}
    	if(d4 == 48 && nz==0){display(32); display(32);}
    		else{display(d4); display(44);}
    	display(d3);
    	display(d2);
    	display(d1);
    	display(72);	//H
    	display(122);	//z
    void clock(void){
    	EN=1;
    	__delay_us(25);		//if you have a newish LCD you can try to reduce the clock pulse width to 10us.
    	EN=0;
    	__delay_us(25);
    void clear(void){
    	RS=0;
    	PORTB=0; clock(); PORTB=1; clock(); 	//clear display
    	PORTB=0; clock(); PORTB=2; clock();	//return home
    	__delay_ms(2);					//2ms
    void display(char fig){
    	RS=1;
    	PORTB=(fig >> 4); clock();			//send 4 MSB
    	PORTB=fig & 0b00001111; clock();	//send 4 LSB
    	RS=0;
    finally i google for LCD code to measure frequency .
    but i dont know how he initialize for LCD .how he make calculations???
    for example
    Code:
  6. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    can anybody help me,
  7. (*steve*)
    25,501
    2,841
    If the solution to a problem is trivially easy to find on Google, then we're not going to waste our time re-typing it for you.
    If you've tried to find it and can't, then perhaps we can point you to a page or suggest a search that will find it.
    If you've found stuff, but it's not useful or you can't understand it, then you need to tell us why, or explain what it is you don't understand.
  8. (*steve*)
    25,501
    2,841
    In terms of initialising your LCD, you'll need to google for something like "PIC initialise <LCD model>".
    Have you told us what the model is? Often the controller IC is most important here.
    Many are HD44780 compatible, certainly those in the 8x1, 16x1, 16x2, etc. sizes.
  9. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    When you calculate (or convert from binary to ASCII) you need to adjust the 'total' with the value from the previous digit. something like this:
    dx=int(number/divx)
    number = number - (dx*divx)
    dx-1=int(number/divx-1)
    number = number - (dn-1*divx-1)
    And so on until the number is in the range 0-9.
    To get this correct you need to validate/test that the startvalue of number(total) is less than divx*10 before you start, or you'll get dx >9
    When you display this you only need to add 0x30 (48 decimal) to each digit before you write it to the LCD.
  10. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    i'm making simulation on proteous and using 16x2 LCD.
    that is available in proteous library
  11. kingrosekhan123
    kingrosekhan123
    19
    Apr 14, 2013
    if anyone have code for frequency counter using ccp,kindly share it to me .
    that is easy to understand.
    Thanks..
    kingrosekhan123
Similar Threads
Loading...
