P
panfilero
ok, basically I want to turn on and off an analog switch wirelessly.
The range I need is very short... maybe around 20ft. And I need a
transmitter as small as possible, and hopefully can run on a small
battery (like a key fob and a watch battery). The transmitter only
needs to be able to send 1 command to the reciever which would in turn
tell my analog switch to open... I don't care how big the reciever
is.... and this setup needs to be very responsive so that if someone
taps the button on the transmitter side 10 times in 1 second, the
reciever can open the switch 10 times in 1 second... very minimum
delay, unpercitable... instant! I only want the switch to open while
the button is pressed at all other times the switch should be
closed....
anyway, that's basically it.... can anyone make any suggestions or
point me in the right direction as far as where I could find a
reciever and a transmitter that would fit my criteria? I imagine...
its a pretty simple/basic application... but I know nothing about
reciever/transmitters....
much thanks!
closed....
much thanks!
