Need help repairing Microwave oven
Discussion in 'General Electronics Discussion' started by Ensing, Aug 25, 2021.
  1. Ensing
    Ensing
    Aug 25, 2021
    I've a extra-large, 30-year-old, 'National' Genius microwave oven.
    It is only partly working.
    And I'm in COVID19 Lockdown in New Zealand.
    Can anyone help me to diagnose the fault(s)?
    I have no electrical or electronic training and
    don't expect to be able to fix it.
    However, I have tools. And perhaps you could ask me
    questions that could help you to diagnose possible
    reasons for the fault(s).
    So I'm hoping for your expert help to diagnose the fault in the microwave over Lockdown as the family need it. If it is not-repairable, I'll buy a new one online. But I'd rather have this old one repaired.
    It is large and made with quality.
    And no repair shops are able to be open - deemed non-essential.
    Can you, forum members, talk me through a diagnosis
    and possible repair?
  2. DBingaman
    DBingaman
    108
    28
    Jun 27, 2021
    Check out this video, might help. You will at least need a DMM at minimum to troubleshoot with:
  3. Bluejets
    Bluejets
    5,145
    1,075
    Oct 5, 2014
    Just a note on the video.....I would not recommend any type of live testing especially since the Op has identified his electrical knowledge as zero.
    hevans1944 and DBingaman like this.
  4. DBingaman
    DBingaman
    108
    28
    Jun 27, 2021
    True, the Op has no experience in this arena. Microwave ovens have high voltages present. Now that the subject is brought up it is probably not a good idea for the Op to try to fix the microwave on his own.
  5. VenomBallistics
    VenomBallistics
    285
    57
    Aug 30, 2018
    Noob + MOT = Much bad joo joo.
    Our advice should be limited to those operations not involving these parts.
    One flash, you're ash is in full effect.
    You are where seasoned techs fear to tread
    DBingaman likes this.
  6. Ensing
    Ensing
    Aug 25, 2021
    OK. I'll hope for a fault diagnosis? Perhaps that's possible.
    I have an entry level DMM. Still, I'm unqualified.
    I've fixed the drive previously. There's a belt that drives the turntable. I had to make a replacement. The motor was still good. I used a record turntable belt of similar size and had to tweak it to fit. A bit McGyver though. It has worked for 2 years since that repair.
    However, this is more than that. The turntable is not working. The fan is also not working.
    But the microwave still heats food. I'm unsure if this is safe.
    Steams up the oven. And no rotation. So manual rotation, stirring or shifting of the food seems to address this issue.
    I do hear the Hum of the transformer for the magnitron.
    OK. Having watched the video, I see that there can only be several of 100 things malfunctioning. So diagnosis seems to require a lot more work that I anticipated.
  7. VenomBallistics
    VenomBallistics
    285
    57
    Aug 30, 2018
    We get to stay away from big sparky then .
    Are these independent motors for the fan and turn table? Or do they share a common motor
  8. VenomBallistics
    VenomBallistics
    285
    57
    Aug 30, 2018
    you do need the fan at least. turn table is nice but optional.
    given the nature of the stuff in such an appliance, a policy of no live testing while disassembled is prudent.
    that said, trace the wires back from the motor(s) and see if you have blown fuses, tripped breakers or outright burnt stuff.
    Also, if you have an ohm meter, check the motor(s)
    take pictures and share along the way
  9. flippineck
    flippineck
    322
    13
    Sep 8, 2013
    Is there a potential danger from stored charge even after the unit has been unplugged for a while?
  10. Bluejets
    Bluejets
    5,145
    1,075
    Oct 5, 2014
    Obviously you didn't watch any of the video where they make good coverage of that fact.
