Need help on SMD Code
Discussion in 'General Electronics Discussion' started by rambo99, Dec 2, 2011.
  1. rambo99
    rambo99
    58
    Apr 24, 2011
    I have a SMD which I check in SMD Code AS ZMV833ATA but to me it not right Because the company name is ST
    AE
    D302 on the SMD and it not a Zetex Company can any help on this SMD Part
    The Package is SD
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    One important aspect of SMD identification is knowing the case outline. Also, are you saying it's an ST-Microelectronics device labeled AE, with D302 on another line?
  3. (*steve*)
    25,411
    2,779
    Can you tell us what package it's in?
  4. rambo99
    rambo99
    58
    Apr 24, 2011
    SMD
    The Package SD
  5. (*steve*)
    25,411
    2,779
    Sorry, that doesn't help me. I don't know of a package called SD. Examples of package include things like SO-8, SOT-23-5, TSOP-28.
    If you don't know the package it's in, an image next to something for scale would help. Even knowing the number of pins would be a big help.
  6. rambo99
    rambo99
    58
    Apr 24, 2011
    I sorry I can not give you any more Detail as this SMD part is on a Segate Hard Drive the company on this SMD shows ST for the Company and AE it hard to say what this part is because in not in the code book
  7. (*steve*)
    25,411
    2,779
    Can you count?
    How many leads does it have?
    Can you measure it?
    what size is the black epoxy part?
    Are the legs all on one side?
    Does it have a tab?
    There is very little we can do is a vacuum!
  8. rambo99
    rambo99
    58
    Apr 24, 2011
    about 4mm x2.5mm A picture may help
  9. (*steve*)
    25,411
    2,779
    OK, it's a diode. (99% chance based on the stated manufacturer(s) and package)
    Unfortunately I am away from my datasheets etc right now so I can't look it up.
    The ZMV833ATA seems unlikely as the closest package it comes in is a SOD-23 which is about 1.1 x 0.7 mm and it's a varicap diode which I would not expect to see on a disk drive.
    I'll try to remember to look this up later (but with the information you have provided, someone may well beat me to it).
  10. (*steve*)
    25,411
    2,779
    Could it be this package?
    In this package there are a number of TVS diodes rated for 5V working voltage.
    Check to see if this diode is across the 5V rail. If so, it is there to absorb spikes on the 5V rail.
    Some examples are SMAJ5.0A, P4SMA6.8A, P4SMAJ5.0AC, etc.
    The first of these devices in a STMicroelectronics device. See here.
  11. rambo99
    rambo99
    58
    Apr 24, 2011
    yes this is the right one and I will order that part
