Need Help In Program
Discussion in 'Microcontrollers, Programming and IoT' started by vead, Jun 1, 2017.
  1. vead
    vead
    473
    14
    Nov 27, 2011
    Hello everyone
    I want to write C program to do following task.
    first blink LED,
    If LED is blinking than do task for motor start, forward , backword , stop
    if motor is working , display message '' motor working " on LCD
    I have written program individually for each task Now I want to combine all in one program. so I try to make program its incomplete program i need help in main function . I am confused on how to do all in main function
    Code:
    #include <REG51.h>           // Header file of AT89c51
    #define display_port P2      //Data pins connected to port 2 on microcontroller
    #define LED          P1      // LED is connected to port P1
    #define LED_ON       0xff    // LED ON
    #define LED_OFF      0x00    // LED OFF
    //motor connection
    sbit L293D_pin_1 = P3^0;     // pin_1 connected to P3^0
    sbit L293D_pin_2 = P3^1;     // pin_2 connected to P3^0
    sbit L293D_E     = P3^2;     // pin_E connected to P3^0
    // LCD pin connection
    sbit rs = P2^0;              //RS pin connected to pin 2 of port 3
    sbit rw = P2^1;              // RW pin connected to pin 3 of port 3
    sbit e =  P2^2;              //E pin connected to pin 4 of port 3
    // delay function for LED
    void LED_delay (unsigned int i)
        unsigned int j;
        for (i = 0; i < 40000; i++);
    // Delay function for LCD
    void LCD_delay(unsigned int time)  // Function for creating delay in milliseconds.
        unsigned j,l ;
        for(j=0;j<time;j++)
        for(l=0;l<1275;l++);
    // Delay function for Motor
    void Motor_delay()
    unsigned int m,n,k;
    for(m=0;m<0x20;m++)
    for(n=0;n<255;n++)
    for(k=0;k<255;k++);
    void rotate_f()
    L293D_pin_1 = 1; //Make positive of motor 1
    L293D_pin_2 = 0; //Make negative of motor 0
    L293D_E = 1; //Enable L293D
    void rotate_b()
    L293D_pin_1 = 0; //Make positive of motor 0
    L293D_pin_2 = 1; //Make negative of motor 1
    void breaks()
    L293D_E = 0; //Disable L293D
    void lcd_cmd(unsigned char command)  //Function to send command instruction to LCD
        display_port = command;
        rs= 0;
        rw=0;
        e=1;
        msdelay(1);
        e=0;
    void lcd_data(unsigned char disp_data)  //Function to send display data to LCD
        display_port = disp_data;
        rs= 1;
        rw=0;
        e=1;
        msdelay(1);
        e=0;
    void lcd_init()    //Function to prepare the LCD  and get it ready
        lcd_cmd(0x38);  // for using  2 lines and 5X7 matrix of LCD
        msdelay(10);
        lcd_cmd(0x0c);  // turn display ON, cursor blinking
        msdelay(10);
        lcd_cmd(0x01);  //clear screen
        msdelay(10);
        lcd_cmd(0x81);  // bring cursor to position 1 of line 1
        msdelay(10);
    void main()
            LED = LED_ON;
            LED_delay(500);
            LED = LED_OFF;
            LED_delay(5000);
            LED = LED_OFF;
    rotate_f(); //Run forward
    motor_delay(); //Some delay
    breaks(); //Stop
    rotate_b(); //Run Backwards
    breaks(); //Stop
        unsigned char a[15]="motor working";    //string of 14 characters with a null terminator.
        int p=0;
        lcd_init();
        while(a[p] != '\0') // searching the null terminator in the sentence
            lcd_data(a[p]);
            p++;
            LCD_delay(50);
  2. Josh Bensadon
    Josh Bensadon
    8
    Jul 16, 2012
    First thing you must do, loose the delay calls! You are thinking single task, that's why you are failing to get it done.
    Use this code below to do a specific task every xxx milliseconds. Set the variable "interval" to say 100 and this code will execute this task every 100mSec. When NOT executing this task, execution proceeds with the next set of instructions. Use several of these (with different variables of course) in your main loop, one for each task, and then you'll be multi tasking at various intervals.
    currentMillis=millis();
    if ((unsigned long)(currentMillis - previousMillis) >= interval)
    previousMillis = previousMillis + interval;
    //Do this task on a fixed interval
