need help in controlling the voltage in a circuit
Discussion in 'General Electronics Discussion' started by gurjant.sandhu33, Dec 10, 2013.
  1. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    :greetings every one,
    i have made a project on automatically street light controlling by using an ldr. i have used a 6v relay for this. It works fine but when the voltage input to the relay is under 5v it strats to make flickering sound. so, can anyone suggest me a solution to control the current flow to relay upto 6v and after which the current flows normally.
    your help will be really appreciated.
    thanks.
  2. BobK
    7,682
    1,686
    How about using a lower voltage relay.
  3. (*steve*)
    25,387
    2,772
    Sounds like homework.
    Why not Google hysteresis...
  4. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    thanks for your reply sir,
    but my problem is that in my circuit the input to relay varies from 0 v to 6 v and if i will use a lower voltage relay then also at some point this buzzing will occur when the voltage is not sufficient to drive the relay
  5. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    please
    can you refer me a circuit for hysteresis
  6. (*steve*)
    25,387
    2,772
    Sure. Sorry for taking so long.
    LMGTFY
  7. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    thanx...:)
  8. BobK
    7,682
    1,686
    I am going to guess that the problem is that you are simply using a voltage divider with the LDR and a resistor and feeding it to the base of a transistor. If you use a comparator instead, it will work much better, it will snap to the full voltage once the threshold is crossed, and they have built in hysteresis.
  9. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    thanx.....bobk
