need help in 8 bit moving message display using Matrix LEDs
jon.leaves
Oct 5, 2009
5
Oct 5, 2009
5
Hi to everyone... I am new here...
I am working on "8 bit moving message display using Matrix LEDs"
I am just making a prototype.
Please guide me for this circuit....
Thanks in advance.
jon.leaves
Oct 5, 2009
5
Oct 5, 2009
5
Have you worked on circuit diagram ?
I have implemented this project.
I have used 89s51 microcontroller. Made a character of 5x7matrix.
Used Latch IC for each row. Used 3:8 or 4:16 decoder ic.
I have not yet finalized the circuit diagram... I am not familiar with microcontroller programming... Can you tell me if this circuit is cost effective. and have u done programming in C or assembly... because I am very poor in C language.
rushi53
Aug 19, 2009
10
Aug 19, 2009
10
I have used 89s51 microcontroller and have done programming in assembly language.
jon.leaves
Oct 5, 2009
5
Oct 5, 2009
5
How many characters have you designed? I mean 5x7 matrix belongs to 1 character...
Thus how many matrices are there ?
and whats the use of Latch and decoder ICs ?
rushi53
Aug 19, 2009
10
Aug 19, 2009
10
Decoder IC is used to select 1 column of Matrix LED.
and Latch IC is used to hold the data at each column.
I have used 2 ports for decoders and 2 decoders at each port
thus total 4 decoders
each decoder have 8 outputs
thus total 32 outputs from decoder
and each character requires 5 columns,
thus I was able to use 6 characters.
you can use 4:16 decoder, if you want to use more characters.
Thus u can increase columns.
jon.leaves
Oct 5, 2009
5
Oct 5, 2009
5
@rushi53,
thanks for the information
I can now start working on the circuit diagram...
can you tell me what is the programming logic in this
I mean algorithm/flowchart?
powerpisces
Oct 20, 2011
Oct 20, 2011
i need some help to drive dot matrix with out using micro controller.
i need some help to drive led dot matrix without using micro controller. i have designed a digital clock circuit on 7 segment, now i want to implement it now matrix. plz help me. i m 2nd year student so i haven't any brief idea about micro controller and i must implement my circuit on led matrix.
