The electrolytic cap in parallel with the diode is 47uf 50v. The display
doesn't dim so much as it flickers.
The cap voltage would suggest that the zener voltage can't be more
than about 35V, if typical design margins have been employed. The
wattage of the 3K3 series resistor would be handy to know. Is it 1/4W?
1/2W? What other voltage rails are available for the remaining
circuitry? For example, if 15V were available to the sled and spin
motors, but not to the display, then this would suggest that the
display voltage was somewhat higher. What type of display is it? Is it
a vacuum fluorescent display (VFD)? These often have a zener derived
bias voltage. Are there any display driver chips in the vicinity of
the VFD?
Have you tried contacting Adcom?
- Franc Zabkar
