Need help identifying a component
Discussion in 'Troubleshooting and Repair' started by electroguy98, Dec 19, 2019.
  1. electroguy98
    electroguy98
    Dec 19, 2019
    Hello..I was trying to replace the left analog stick of my ps4 controller and while heating the solder pads with a hot air gun I burnt the connector circled in the picture. I need help in identifying the component and also from where I can get it. If not possible then please let me know if there's an alternative.
  2. bertus
    bertus Moderator
    1,680
    651
    Nov 8, 2019
    Martaine2005 likes this.
  3. Martaine2005
    Martaine2005
    3,322
    910
    May 12, 2015
    I doubt Sony used ‘off the shelf’ parts. Heck, all their solder joints dried or cracked through the 80s & 90s. The individual connectors pitch might match some readily available multi pin connectors, but they may not mate/lock together.
    If I were you, I would buy a broken/ non working controller and re-use the connectors, cables, switches etc. OTOH, you can always change both for ‘off the shelf’ multi connectors. Yes, a PITA but doable.
    Martin
    Bluejets likes this.
