Need Help Identifing Transistors
alfa88
Dec 1, 2010
349
Dec 1, 2010
349
I tore into a 20 year old pager radio and these transistors were in the power amp section. The boards they are on were mounted on massive heat sinks. I tried a Google search and a NTE cross ref and came up dry. A Motorola 587-3737-000-B and a RFP100-100RH (manufacturer unknown).
davenn
14,264
14,264
The RFP100-100 is an atteuator resistor ( Not a transistor)
100W rating and 100Ohms resistance and rated DC - 2GHz
I see items from this company on a number of RF units I work on
Google is your friend :) the first hit was for that device ;)
You will probably find that that part # on that Motorola device is an inhouse number and you wont find any references to it
it will be a device made only for another RF company to their specifications. I suggest that because it doesnt mantch any of the standard Motorola numbering systems. Motorola will NOT release data for it
chris309
Jun 15, 2012
Jun 15, 2012
m 987-3737
View attachment glenayreamp.bmpThe Motorola m 587-3737 is a custom rf transistor used in a known pager power amp. these devices are capable of 45 watts cw in the 900 to 960 mhz. B+ of 26 votes.
the bord you have has a part # of 263-0019-035. and the power amp palate can delver 90 watts.
the other 2 components are 100 ohm ballast resisters.
with 6 watts drive per transistor will produce full power.
good luck and have fun.
Daugherty
Jun 24, 2022
Jun 24, 2022
After 25 years in the paging industry I found a Glenayre Amp that needs that transistor. I should have bought Hen's teeth when they were available. Hindsight 2020! So now I am happy to buy junk PAs.
megahan9
Jul 14, 2022
Jul 14, 2022
I have lots of Glenayre equipment and many of these Motorola transistors would you willing to purchase
megahan9
Jul 14, 2022
Jul 14, 2022
What do you have and what are you asking?
I have a lot of old telecommunications equipment I’m trying to sell it before I scrap things for gold I was seeing if people might value it more not scrapped and as is if you would like to email me at [mod edit: private E-Mail removed for privacy reasons. Please use PM (conversation) for contact] I have a lot of inventory I can send photos to you
roughshawd
Jul 13, 2020
466
Jul 13, 2020
466
try alldatasheets.com
boo hoo!
you just rained on a parade in 2000...
good luck.
