need help flip flop truth table
vead
Nov 27, 2011
473
Nov 27, 2011
473
when the value of flip flop input are known how to find out the flip flop output I want to find out the output of d flip flop
truth table
D Clk Qn|
0 0 |
0 1 |
1 0 |
1 1 |
how to find out Qn ?
Harald Kapp
13,743
13,743
First I think this is homework, so I'll move the thread.
Second: the state of Q is not important. Flip-flops are typically edge triggered. The state of a flip-flop changes with either the rising edge (clock from 0->1) or the faling edge (clock from 1>0), depending on the type of flip-flop.
You also need to know what type of flip-flop you have. There are many different types like RS-FF. JK-FF, D-FF and others. From your simple truth table one can assume you have a D-flip-flop. A D-flip-flop changes the output to the same state as the input with a clock edge.
Now:
- find out what clock sensitivity (rising or falling) your flip-flop has
- find out what type of flip-flop you have
Then you have everything tocreate a meaningful truth table.
vead
Nov 27, 2011
473
Nov 27, 2011
473
Now:
D flip-flop positive edges
clock input changes from 0 to 1 (rising edge)
when clock is rise what will be the Qn
when clock is not rise what will be the Qn
vead
Nov 27, 2011
473
Nov 27, 2011
473
Now:
when clock is rise Qn will become as D input
D Clk Qn
0 0
0 1 0 clock is raising from 0 to 1 so Qn will become as same as input D
1 0
1 1 1 clock is raising from 0 to 1 so Qn will become as same as input D
when clock is not rise what will be the Qn?
Harald Kapp
13,743
13,743
A flip-flop is a memory element. It will remember the state of Q and change only on a clock edge.
vead
Nov 27, 2011
473
Nov 27, 2011
473
i want to ask when clock is not rise what will be the Qn?
D Clk Qn
0 0 ? what will be 0 or 1 and why?
1 0 ? what will be 0 or 1 and why ?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
To repeat what you've been told.
Q only changes on the rising edge of CK.
So is is unchanging when CK is high, low, or falling.
So, what value does it have? (Hint: Ask yourself what value it had)
Harald Kapp
13,743
13,743
D Clk Qn
This truth table is useless. There are no clock edges to show the change in Q. Also the state of Q depends on the state of D during the active clock edge.
Normally you use symbols to note these key elements in the truth table.
Hint:
Use e.g. ^ to indicate a rising clock edge (active)
Use e.g. x to indicate a don't care (state of the signal can be 0 or 1 without any
difference)
Use Qn-1 to indicate the state of Q shortly before.
Make a table like this:
D clk | Qn
x 0 | Qn-1 <- the state of Q doesn't change when clock is 0
x 1 | Qn-1 <- the state of Q doesn't change when clock is 1
0 ^ | ??? <- place your answer here
1 ^ | ??? <- place your answer here
You may also look up the datasheet of the7474 integrated circuit which explains the operation of a D-type Flipflop.
vead
Nov 27, 2011
473
Nov 27, 2011
473
Hint:
difference)
D clk | Qn
D clk | Qn
0 0 | ? the state of Q doesn't change when clock is 0 what will be Qn 0 or 1 and why
1 0 | ? the state of Q doesn't change when clock is 0 what will be Qn 0 or 1 and why
0 1 | ? the state of Q doesn't change when clock is 1 what will be Qn 0 or 1 and why
1 1 | ? the state of Q doesn't change when clock is 1 what will be Qn 0 or 1 why?
0 ^ | 0
1 ^ | 1
(*steve*)
25,510
25,510
D clk | Qn
it will be Qn-1 (assuming that Qn-1 is the state Q was in some small time earlier.
why? Because that's the function of the device!
You haven't given the states on a falling edge either.
vead
Nov 27, 2011
473
Nov 27, 2011
473
ok if someone say draw the truth table for D flip flop so what is the truth table for D flip flop
Harald Kapp
13,743
13,743
That's what you're supposed to find out, isn't it?
Maybe you should try to understand how a D flipflop works. Just copying a truth table someone else has drawn will not help you. This page explains D-flipflops in detail. Please read it and try to understand what is said there. If you still have questions after that, come back here.
