Need help finding a solution - switch / Help for a noob - relays
Discussion in 'General Electronics Discussion' started by alon, Jun 7, 2011.
  1. alon
    alon
    Jun 7, 2011
    Hi guys,
    I'm in need of a specific switch that will allow the following:
    - The switch needs to have 3 contacts (legs)
    - Switch OFF -> no contact between any of the legs
    - Switch ON -> contact between all of the 3 legs
    I've looked everywhere, but I couldn't find anything that fits.
    Can you advise on a switch that will fit?
    Also,
    I was wondering, if I take a simple 3 leg on/off rocker switch and connect 2 of the leg with a diode, will it solve it?
  2. davenn
    davenn Moderator
    13,671
    1,892
    hi there welcome to the forum
    I think you need to tell us all more about what you are actually trying to achieve
    I can only assume that you dont really want to short circuit the + and the - of a power supply as shown in your diagrams ? as that would result in a blown power supply
    cheers
  3. BobK
    7,682
    1,686
    You could use a 3PST switch to achieve this:
    o----/ o-----+
    o----/ o-----+
    o----/ o-----+
    Connect your three wires to one side of the 3 switches, and connect the other side of the three swiched all together.
  4. (*steve*)
    25,418
    2,788
    You could also use a DPST switch. Just replace one of the switch contacts shown above with a link. DPST switches are far more common too.
  5. alon
    alon
    Jun 7, 2011
    Hi guys,
    I have a simple circut,
    3 negatives (with no contact between them)
    1 positive (12V)
    I need to be able to conect the positive to the 3 negatives using a simple on/off switch.
    I assume the best way to do this is using a relay.
    - Am I right?
    - What kind/type of relay can I use?
    - How should the circut look?
    Thanks in advance,
    Alon
  6. shrtrnd
    shrtrnd
    3,773
    493
    Jan 15, 2010
    This is probably an engineering question. I'm a tech.
    I think in terms of physical connection. I don't understand from the drawing, what it
    is you're trying to do.
    If this is theory, some engineer can probably figure-out what the drawing means.
    But for us hands-on guys, we'd need a little more information, about what it is exactly,
    that you're trying to do.
  7. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    I merged your two threads since they seemed closely related.
    I'm sorry I can't help you with any of your circuits, you're being too vague, and also using confusing terminology, so I can't tell you what you really need to know.
  8. poor mystic
    poor mystic
    1,067
    31
    Apr 8, 2011
