Need help finding a replacement fuse
A
Art
I have a Technics SA-GX500 receiver that stopped working -- turns out
it's a blown fuse and I'm having a really hard time finding a
replacement. It is a glass cartridge fuse, 125V 5A, has the code SOC
ST6 on it, and is approximately 32 x 5 mm. I combed through Google
search results, Radio Shack, Panasonic/Technics, etc but no luck.
Anybody have a reliable source where they think I could find this?
Art
Art said:
Art
Hi Art
I see you have tried to search around for your fuse, I lived in St.
Louis at one time and there is a manfacturer there names Bussman Fuse
Company, if memory serves me they are in a western suburb of Manchester
or Creve Cour. Other alternative is to change fuse holder for a more
common physical size to accept the fuses with the ratings you need.
Yours
Mike
H
Homer J Simpson
Isn't that the standard European size? Mouser?
R
Ross Herbert
Art
That will be a common 3AG type fuse(1-1/4" x 1/4" or 31.8mm x 6.35mm).
If there is a T before or after the 5A marking it will be a delayed
action fuse. This type is common for fuses used ahead of switch-mode
psu's. Should be available from almost any electronics parts supplier.
S
Sam Goldwasser
Of course, the power supply may be shorted which blew the fuse. However,
fuses do sometimes blow on their own or due to a power surge so it's worth
trying a *single* replacment fuse. If it blows, then troubleshooting of
the power supply will be necessary.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
