Need help determining what kind of fuse this is?
irishluck
Mar 12, 2014
57
Mar 12, 2014
57
Need help determining this fuse type. The markings on it says "VW-1 H" or thats atleast all I can see.
Need to get a replacement one.
davenn
14,262
14,262
looks more like a resistor
show a sharp and well lit pic of the PCB where it came from
irishluck
Mar 12, 2014
57
Mar 12, 2014
57
Well thats what I thought too but it is a fuse. I took the outside rubber case off (the black stuff) and its a glass fuse.
Ohmed the good one out and measures like a fuse. Ohmed the bad one out and its busted.
Indication on the PCB board shows F1 and F2
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
VW-1 is just a fire retardant rating for the sleeving. Usually the fuse ratings are stamped on the metal ferrules.
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
Fuses like that are referred to as 'pico' fuses.
Use a magnifying glass and see if you can find ANY other markings on your bad fuse.
I don't know how-else to determine what the rating might be.
irishluck
Mar 12, 2014
57
Mar 12, 2014
57
Yea you guys were right. I actually took it to my job and had to look at it under a microscope to find the markings. It was also covered in the melted plastic but its a 3A 250v fuse. But didnt know it was called a pico fuse. Appreciate the help
bsco
May 8, 2011
33
May 8, 2011
33
Pico fuses..I had thought that they were sealed....If you look at the inside of a RJ11 telephone connection box like the ones that mount on your baseboard,(or some tele-communications equip)... you will probably find two very small green colored components inside..they are used to help protect the equipment from spikes on the phone line.... the rating is printed on the body...These are pico fuses......if you can remove the outside covering, then I don't think they are pico style...the fuse that you had I have found inside power supplies inside some orion laser lights....they just have a black covering over them which looks like heat shrink tubing.........
