Need help designing an Antenna!
Discussion in 'Electronic Design' started by zoti, Apr 22, 2006.
  1. zoti
    zoti Guest
    I'm trying to design a replacement antenna for a GSM phone. One that
    will cover 850MHZ, 900MHZ, 1800MHZ and 1900MHZ (Quad band GSM).
    Doing a bit of reading on the internet I came up with an antenna that
    is made out of a piece of wire at 1/4 length of the average frequency
    (1350MHZ). The antenna is just over 5CM (2 inches) long.
    It seem to work fine and I get good reception with the phone but here
    are my questions.
    - Do I need to take anything else into consideration? Like the
    material the antenna is made of?
    - Did I even do my calculations right?
    zoti
  2. Sunkist
    Sunkist Guest
    Your best bet is to search the Ham Radio Websites, there are programs
    designed to calculate the exact length. The problem is that if the
    Antenna is optimum for one Freq it wont be for another, but, the
    antenna at 1800Mhz if it's a 1/4 wave is 1/2 wave at 900Mhz (inversely
    Proportional, higher freq = shorter wave). Because you cant have a full
    wave antenna the best option is 1/4 wave at 1800Mhz.
    1/4" Pipe Copper is best, the thicker the conductor the wider the
    bandwidth. The length is critical because of "standing wave ratio", and
    RF that cant get out of the Antenna is fed back into the Transmitter
    and will burn it up. You also need a Corona Discharge Ball on top to
    dissipate static. If there is a reflector that reflects wave away from
    your Head (brain) that might complicate matters.
    If you want the best reception and transmission, your best bet is to
    keep the Antenna vertical at all times as the Cell transmits on a
    Verticle Axis.
    Maybe be better off to switch to a service provider that has more cells
    in your area?
    Regards, Joe
  3. Ken Taylor
    Ken Taylor Guest
    Of course we all know you meant to say that a 1/4 wave at 900MHz is 1/2
    wave at 1800MHz, not the other way around.
    One thing the OP needs to keep in mind is that the antenna needs to be
    matched correctly for the output stage of the phone in question - it may
    not like to transmit into the antenna you make for it. Chances are all
    will be okay, but.....
    Cheers.
    Ken
