Need help choosing components
Discussion in 'General Electronics Discussion' started by geth3, Oct 30, 2010.
  1. geth3
    geth3
    4
    Sep 9, 2010
    I need these, but I'm new to electronics so I have no idea what they are.
    I need them from this website Rapid Electroincs
    Please could you send me a link for each of these:
    10uF capacitor
    10k variable resistor
    555 Timer
    Resistors:
    470ohm
    1k
    560ohm
    180ohm
    4.7K
    10K
    1K
    1M ohm
    high speed switching diodes 1N4148
    transistor - BC557
    10nf capacitors
    1uF Capacitor
    Thank you!
  2. Ian
    Ian Administrator
    1,481
    431
    Aug 23, 2006
    There's a search box on the Rapid Electronics website, so it should be easy to find those components ;). I don't think you'll get anyone looking up each individual one on your behalf, but we can help you if you get stuck.
    If the search brings up a lot of results, do a manual search for the components. For example, those resistors can be found in this section:
    http://www.rapidonline.com/Electronic-Components/Resistors-Potentiometer
    Just pick the type you want - I guess you're after some cheap Carbon/Metal film resistors - so just select the type you are after.
