Need help building a push switch box with indicator light
Discussion in 'LEDs and Optoelectronics' started by Dwayne Brown, Aug 30, 2017.
  1. Dwayne Brown
    Dwayne Brown
    5
    Aug 30, 2017
    Hello I have a fog machine with a rocker switch (PRONIC R13) it has an indicator light in it that comes on when the machine heats up and is ready to use. What I need is a box with a push switch that i can operate with my foot. I have a switch box . I cannot find a momentary switch with an indicator light but I assume I can somehow hook up a push switch with a separate light I know little about doing something of the like but if I had a diagram to go by I'm sure I could hook it up. 20170830_175303.jpg 20170830_175342.jpg 20170830_175427.jpg 20170830_175303.jpg
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Welcome to EP.
    It is not clear what you want to do.
    Do you want to extended the distance of the power-on switch and indicator light from the smoke machine?
    What is the purpose of the momentary switch?
    What smoke machine do you have?
  3. Alec_t
    Alec_t
    2,957
    803
    Jul 7, 2015
    If you use a double-pole switch of appropriate rating you can use one pole to switch the main function and the other pole to switch an indicator light.
  4. Dwayne Brown
    Dwayne Brown
    5
    Aug 30, 2017
    The smoke machine is an FM-400P the momentary switch is so I can activate the switch with my foot giving short bursts of smoke. its too hard to operate by my foot with the rocker and if I don't shut it off right away I choke everybody on stage.
  5. Dwayne Brown
    Dwayne Brown
    5
    Aug 30, 2017
    the 4 pin rocker switch has three wires connected with one pin open. I want to know how to wire the foot switch and the separate indicator light from those three wires.
  6. Alec_t
    Alec_t
    2,957
    803
    Jul 7, 2015
    If those are internal connections it sounds like the switch is effectively a single-pole type.
  7. Dwayne Brown
    Dwayne Brown
    5
    Aug 30, 2017
    Yes I think so , Ive been doing some reading and I think a SPST is what i am loking for and I think I have the wiring figured out. what do you call a push switch that is normally in the off position and automatically turns off when you take your foot off the switch. on/on or on/off
  8. Alec_t
    Alec_t
    2,957
    803
    Jul 7, 2015
    I'd call it a momentary-on switch.
    Here are some DPDT examples, listed as 'On-Mom'.
  9. Dwayne Brown
    Dwayne Brown
    5
    Aug 30, 2017
    OK thanks for the information .. I appreciate it
