need help - automatic oiler circuit
Discussion in 'General Electronics Discussion' started by rd400g, Apr 30, 2013.
  1. rd400g
    rd400g
    Apr 30, 2013
    Hi everyone,
    I am building a system to auto dispense a small amount of chain oil to keep the chain on my motorcycle lubricated.
    So far I have decided on the type of pump and have ordered it you can see it here. http://www.ebay.ca/itm/261147586500?...84.m1439.l2648
    And this is the controller I chose at this point that is adjustable from 1 to 300 seconds. It has two pots so I can adjust how long it pulses the motor for which I imagine will be no longer than 1 sec every 2 mins. http://www.ebay.ca/itm/400447996083?...84.m1439.l2648
    I have a 12v source wire that lights up a bulb to tell me the bike is in neutral. I want to use this wire as a signal to start the timer circuit operating the pump. I need to buy or make a small circuit that will NOT send power to the timer when the neutral wire 12 volts then allow it through when there is 0 volts.
    Looking for a simple small design that i can put near the timer board and tape them together so it is one compact module.
    Need help... thank you everyone.
    JH
  2. CDRIVE
    4,960
    652
    May 8, 2012
    The pump you chose is 6V but you have a 12V system. I didn't see the current draw listed either. Are you sure it'll stand up to oil? Some plastics soften to oil exposure.
    Chris
