Need fuse
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
Hi all,
Recently I made a AC to DC converter with a 12 -0-12v transformer with 1 ampere rating. Can I use a 1 ampere fuse on the secondary side? If not what should I use. Please help.
davenn
14,254
14,254
Hi all,
depends on what you are going to power from the PSU ?
if the device is substantially less than 1A, then so should be the fuse
if the device will be approaching 1A, then a 1A fuse would be appropriate
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
What do you mean by approaching 1A?
davenn
14,254
14,254
1A fuse will protect the PSU, if you are going to have a smaller current drawing load then use a smaller rated fuse to protect the load
re-read what I said in my earlier post
