Need Flyback TX
Discussion in 'Electronic Repair' started by jim tierce, Jul 5, 2006.
  1. jim tierce
    jim tierce Guest
    Hello,
    I am looking for a working new or used flyback transformer for RCA Model
    F27672ETFE2, Chassis # CTC187BD2, RCA part #227482 .
    I have not found a supply house with one in stock.
    Thanks for your help.
    Jim Tierce
  2. Franc Zabkar
    Franc Zabkar Guest
  3. Guest
    I am sure that part # is discontinued, However if you can locate a
    215540 IHVT & compare the pins to your old one it may work. Sometimes
    RCA changes the # of trans. & drills the chassis for both Numbers .
    Check the spacing on #1 & 12 & look at cir bd
    If you don't do any good let me know & I will check around with the
    other shops for a junker with a good one
  4. kip
    kip Guest
