SinisterSF
- Jan 4, 2018
- 2
- Joined
- Jan 4, 2018
- Messages
- 2
I build custom classic cars and I regularly dabble with normal electronics in a car but I want to build something a little abnormal. A lot of new cars have gone away from a shifter cable attached to a shifter lever. Land Rover, Jaguar, Mercedes and many others have dials and buttons that send an electronic signal to a servo or actuator that turns the lever on the side of a transmission to shift it into gear. There are crazy expensive kits that do this but they're ugly and meant more for racing. I attached a picture of the kind of dial I want to use, I hooked up power to it and I can see that power comes out of specific terminals based on where the dial is turned to. I want to setup an actuator or servo that will push or turn the transmission lever to one of the 4 different positions based on where the knob is turned.
Thanks!
Thanks!
