L
[email protected]
I need to control a bath circulator/chiller. The analog input control
accepts 10mV per degree C. Positive voltages result in temperatures
above zero C, negative voltages (referenced to analog ground) result
in temperatures below zero C. I've build positive voltage supplies,
and negative voltage supplies, but no supplies that swing both ways.
What's the best way to do this? I was thinking of using a positive
supply but instead of connecting the ground directly to the analog
ground, connecting to a voltage divider with a 10:1 split. Would this
work?
work?
