josephkk
So do I and it dopesn't have modulation problems. But these are too big
even if I'd remove the enclosure and power supply.
The problem with the uC on these little boards is not the serial link.
Well, at least not if 100Hz sweeps suffice. The problem is that they are
too small to calculate the numbers on the fly and usually have to little
flash left to store them in a LUT. Plus that would be a major
time-consuming hack.
If i could get you to stop and listen i could show you haw to do the
operating side in very little code space, no lookup table, fixed point
math without divides. The user interface or system interface is another
matter though.
