Need Clamp-on ammeter
Discussion in 'Electronic Basics' started by Nick Hull, Jan 6, 2004.
  1. Nick Hull
    Nick Hull Guest
    I'd like to find a decent clamp-on ammeter to test and adjust the
    circuits in my house breaker box. I doubt I need more than 50 amps, but
    I would like a small & nimble probe to fit in that wiring maze. Is it
    possible to get a max reading model so I can read the max amps on each
    circuit? I'd like a cheap one, maybe $100 if possible.
    Any good suggestions as to what is availiable?
    Nick
  2. Guest
    Probably many available on EBay.
  3. Have you checked Harbor Freight, Sears, or MCM Electronics? Some
    analog clamp-ons cost only $25, but I once saw a digital AC/DC at
    Sears for $45 (maybe with discount coupon), but it wasn't true RMS and
    needed AAA batteries. MCM has an AC/DC clamp-on adapter for regular
    meters (1mV per amp), #72-7164, $37, but it has to be zeroed manually.
  4. Wade Hassler
    Wade Hassler Guest
    The Fluke T600 is about $129, but it does not need to be clamped-
    merely straddles the wire to be measured. Measures resistance from
    1-1000 ohms, voltage to 1-600 AC/DC and current .1-600 AC/DC. And can
    be dropped a fair distance without breaking.
    Wade
  5. Grumpy OM
    Grumpy OM Guest
    I bought a A.W.Sperry DSA-400 some years ago from Home Depot. Less
    than $100. Got it to monitor my water pump current. Works great. This
    one has a data hold feature. Other one available that measures peak
    current.
    Grumpy
