Jason said:
Hi Fred,
Thanks so much for the assistance with this.
Your modification below actually worked a lot better than the original (I
decided to go with the modified schematic because I didn't have a CMOS
555 handy). It's working more normally now =) - I am wrapped!
But there's just some very minor issues now that I hope you could sort
out for me...
1. The first beep appears to be longer than the second and third (I know
you mentioned something earlier about a diode, but I didn't quite
understand). I take it that's because the 555 has just come out of a
reset? So as a result, if I connect, say, the 3rd INPUT for three beeps,
I hear: beeeep! beep! beep!
Right- the 555 pin 5 ,CONT, is the first node of an internal R-R-R voltage
divider to GND which is the threshold for the THRESH switch point, and 1/2
the CONT voltage is the threshold for the TRIG switch point. By connecting
a small diode from CONT to OUT with anode at CONT, when OUT is high, the
diode is back biased and does not affect the trip point for THRESH, but
when OUT is low, which means the timing capacitor is being discharged
downwards towards the TRIG threshold, the diode pulls the internal CONT
node down to 0.7V making the new TRIG threshold ~0.35V. In your
application, when you remove RST, the first beep lasts for the time it
takes the timing capacitor to charge from 0 to THRESH threshold of 2 x
Vcc/3, then goes off for the time it takes to discharge to 0.35V, then
back on for the time it takes to re-charge from 0.35V to THRESH threshold,
then off for time to discharge back 0.35V, etc...All the ON times are
about the same for practical purposes this way. Without the diode the
second and third on times would be of duration the time it takes to charge
from 1/3 Vcc to 2/3 Vcc- and they sound noticeably shorter than the first
beep.
2. With the 10K resistors connected in series and also the 1M drop-downs
for each input like you said, once I disconnect an input (after beeps
have finished), I would hear a very brief 'Blip!' from the buzzer. I
actually thought maybe the 1uF cap had something to do with it, but still
does it even if I remove it.
When a last input is removed, the input NAND gate RSTs the 4017 and drives
the base of the 2N3904 all at the same time. The RST of the 4017 removes
its base drive from the transistor tending to turn it off while the NAND
is applying its drive turning it ON. The NAND base drive part should be
solidly on several hundred nanoseconds before the 4017 outputs begin to
remove their base drive so that I am at a loss to explain why you are
hearing a blip. If you are manually removing a clip lead or using a
switch, which has bounce at turn-off, then an intermittent
disconnect-connect-disconnect etc jittering of the input contact, however
brief, may be causing the blip you are hearing. You can eliminate the
effect, for reasonable jitter of input connection times, by adding a
filter capacitor from collector to base of the 2N3904. This will make the
transistor have a fast on- slow-off characteristic and help prevent the
blip. A schematic with all the changes:
View in a fixed-width font such as Courier.
. 5V
. 1U |
. GND----||--+----[100K]----+---------.
. [10K] 10K] |
. | | _ | | |
. | 3x 1N4148 '---| \ | | |
. | | o-. | --------- |
.IN1----+----[10K]---+-|>|--+---|_/ | +----|RST OUT|--+---+
.IN2--+------[10K]-+-|-|>|--+ | | | 555 | | |
. | | | | | | | | | OSC | | |
.IN3+--------[10K]-|-|-|>|--+ | | | | | BEEPER
. 1M | | | | | [100K] | | | | | |
. | | | | | | | | | .-|CONT | | |
. |1M | | | | GND | | | | | | GND
. | |1M | | | | | | --------- |
. | | | | | | | | | gnd |
. GND | | | | |
. | | --4017-- | | | 1U |
. | | | Q0| | | \| |
. | | |-- | | | 2N3904 |------+
. | '---|CE | | | <| |
. | | | | | _ 4011 | |
. | '1'-|CLK Q1|--------| \ GND |
. | | | | | | o _ |
. | | | | '--|_/ '-| \ |
. | | | | _ | o--[10K]--+
. | | Q2|--------| \ .-|_/ |
. | | | | | o' |
. | | | '----|_/ |
. | | Q3|--------------------[10K]--+
. +-----|RST . | |
. | | Q9| |
. | | | .-----------[10K]--'
