Need audio vco circuit
R
royalmp2001
I need a simple and cheap circuit for a voltage controlled oscillator
that will drive a small speaker with an audible tone. The voltage
range will be 0-1V from across a 1K resistor in another circuit.
S
Spehro Pefhany
Assuming square wave or triangle will do you, check out the VCO
circuit on the LM324 datasheet. Can't get much cheaper/easier. If the
speaker is low impedance you'll need a buffer on the output, or if you
just need "audible", use a series resistor to knock the output current
down to single-digit mA.
Best regards,
Spehro Pefhany
K
Ken Smith
How about a CD4046?
R
royalmp2001
Sounds good, Ken...where can I find such a circuit?
John Popelish
You design it. The 555 has quite a bit if what you need, inside. It
has the threshold sensor and the discharge switch. You add a flip
flop to the pulse output to get a square wave. And you have to come
up with a variable current source to charge the capacitor that is
controlled by a second 555 oscillator to do the sweep. Hence the name
of this group. ;-)
K
Ken Smith
Please explain "find such a circuit" in this context. Do you mean find a
CD4046? Do you mean find an existing application? Do you mean find a
schematic with part values?
R
royalmp2001
sorry, Ken
I mean what does the schematic look like. I'm no designer.
K
Ken Smith
sorry, Ken
Get a copy of the data sheet and app-notes for the CD4046 and read them,
ignoring the stuff about the phase detector and looking carefully at the
VCO section.
M
Mark Jones
VCO section.
See a photo of an interactive spreadsheet calculator for the 4046:
http://groups.yahoo.com/group/jallist/files/heliosstudios/4046CalcRevA0.4.png
Perhaps I could make a Win32 executable equivalent with MASM32. Uggh, another
project. :)
-- "Rightousness is found within one's self, not in the demoralization or
subjigation of others." MCJ 200411
