Need an Isolation Transformer?
Discussion in 'Electronic Basics' started by amdx, Sep 24, 2013.
  1. amdx
    amdx Guest
    I needed isolation from the line today, it reminded me of something I
    learned while building a Cockcroft-Walton high voltage generator.
    Use two transformers back to back.
    Example, you have two 120V to 12V transformers,
    (120v in 12 out) connected to (12v in and you have 120V out).
    Or any two transformers with the same secondary voltage.
    Current limit depends on the transformer size.
    It works in a pinch.
    Mikek
  2. Phil Allison
    Phil Allison Guest
    "amdx"
    ** Not a good way at all.
    The second transformer in the chain has to be driven in reverse and that
    leads to large magnetising currents which the first must supply.
    You can wind up with almost no capacity left for the load.
    .... Phil
  3. amdx
    amdx Guest
    You may be right Phil, or it might work with some transformers and
    not others. I did use the 10kV from the Cockcroft-Walton multiplier to
    drive an electrostatic motor. (very little current)
    I gave the motor to the local science museum,
    and they threw it a away. :-(
    Motor plans here;
    http://amasci.com/emotor/emotor.html
    Mikek
  4. Shaun
    Shaun Guest
    "Phil Allison" wrote in message
    "amdx"
    .... Phil
    Phil knows this, he has connected to primaries of the second transformer to
    his gonads and was not impressed by the small tingle he received.
  5. Phil Allison
    Phil Allison Guest
    "amdx"
    ** It never works very well and is worst with small transformers. So called
    1:1 transformers are not *wound* 1:1 - rather their voltage ratio UNDER
    LOAD is 1:1.
    For example:
    Imagine two 120V to 12V trannies rated at 24VA with regulation factors of
    15% and ignoring magnetising currents.
    The reverse wired tranny needs 13.8 volts input to give 120 out with NO load
    and 15.9 volts with full load.
    The normal wired tranny will give 12V when loaded - so is way under the
    required voltage.
    The output voltage will only be 12/15.9 times 120 = 90V.
    Magnetising current in 12V winding of the reverse wired tranny makes the
    available VA lower.
    Using two dissimilar trannies ( to fix the above) does not work either, it
    only makes the magnetising current in the reverse wired one huge, soaking up
    all the VA rating.
    What you gotta remember is that AC supply trannies are wound with the turns
    ratio ADJUSTED to give the speced voltage ratio *under load* - PLUS all
    magnetising current is meant to be in the primary, not the secondary.
    ..... Phil
  6. Jasen Betts
    Jasen Betts Guest
    That's OK if you only need a little isolation.
  7. Jeff Layman
    Jeff Layman Guest
    Is it the same for toroidal transformers?
    About 30 years ago I wanted to power a mains voltage pond pump (I think
    50 watts) which was about 10 metres from the house. Not wanting to run
    mains cable all the way, I got a couple of toroidal transformers from an
    electronics surplus shop (now sadly extinct here in the UK). AFAIR they
    were about 12 cm in diameter and 4 or 5 cm high (maybe rated at about
    150 watts?), and had several secondary taps. I found I could get the
    pump powered by using 33v from the first transformer, connected at the
    far end to the 17v tap of the second one. Must have given about 230v on
    load. The pump worked continuously for years using this arrangement.
