Need a VI Curvetracer, simple and cheap
Discussion in 'Electronic Equipment' started by Klaus Kragelund, Apr 27, 2007.
  1. Hi
    I need a curvetracer for lab use. Simple stuff like V/I
    characteristics for small signal (<1A) MOSFETs and diodes and stuff.
    Does anyone know of a cheap one that connects to a PC (via USB or
    disc)?
    I have looked at the Keitley and Agilent types, but the starting price
    is about 20k USD for these types
    Regards
    Klaus
  2. Robert Baer
    Robert Baer Guest
    You could make your own; a transformer with peak output voltage near
    what you would use, maybe a swithchable diode for single polarity, and a
    few resistors - one for current monitoring and the other for voltage
    monitoring.
    Use your scope for the display.
    Add a variac if need adjustable voltage, other secondaries for
    different voltage scales.
    Cheap and dirty.
  3. DaveM
    DaveM Guest
    Search for "curve tracer" on Ebay. Lots of options, some are dirt cheap
    compared to the current crop of commercial models. I have a couple of the
    Heathkit IT-1121 tracers in my shop right now that I bought on Ebay. Both
    worked perfectly the first time I used them, and continue to work well.
    The IT-1121 will sweep the DUT up to 200V, and will test both BJT and FET units.
    Got them both for under $30 each.
    Cheers!!!
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Life is like a roll of toilet paper; the closer to the end, the faster it goes.
  4. Fred Bartoli
    Fred Bartoli Guest
    Klaus Kragelund a écrit :
    Have a look at ebay. Tek 576-577
    Usually sales for less than USD500.
