Need a servo/motor and controller for a project
Discussion in 'Sensors and Actuators' started by Mysticmayonaise, Jun 17, 2017.
  1. Mysticmayonaise
    Mysticmayonaise
    Jun 17, 2017
    [​IMG]
    I am putting a paintball gun into a Nerf gun, and what I'd like is to have the paintballs stay in the rather large battery compartment, and be pushed upto the paintball gun through a tube.
    I thought using some sort of stepper motor or servo and a controller/arduino to control the motor
    Problem is, that since this is a mechanic paintball gun, it shoots once per trigger pull, then resets, so I cant have a motor constantly pushing balls to it, as they would jam or break.
    So I need a way to push a switch (attached to the trigger) and have that cycle a single ball forward, then rinse and repeat per pull.
    Suggestions for motors, controllers, and maybe a simple switch?
    Thank you
  2. HellasTechn
    HellasTechn
    1,556
    215
    Apr 14, 2013
  3. Mysticmayonaise
    Mysticmayonaise
    Jun 17, 2017
    Yes, the trigger will be pulled manually, and then hit the switch connected to the arduino
    And I may have found a switch I can use, though the one you linked is perfect
