Need a Powerline modem chipset
Discussion in 'Electronic Components' started by fskhan, Jul 16, 2006.
  1. fskhan
    fskhan Guest
    Hi, i am working on a home automation system and doing it using
    powerline communications , I have searched a few IC like philips
    TDA5051 and ST7538 but having problem getting them.
    Can anyone help me in finding any better chip or may be guiding how to
    buy these chip from outside my country(Pakistan) as I cant find them
    here?
  2. Eeyore
    Eeyore Guest
    Maybe you should consider why there's no real demand for these chips instead ?
    Graham
  3. Mochuelo
    Mochuelo Guest
    Don't give us the same bulls**t again. If the guy is asking for info
    on those kind of ICs, don't assume that you know better than him
    whether he needs them or not. Answer his question or shut up. You
    always write the same arrogant comments, as if only you had the
    knowledge or experience --in case you did.
  4. Ross Herbert
    Ross Herbert Guest
    I can well understand your feeling on this and perhaps Eeyore could
    have offered a little explanation for his comment and he would have
    avoided a response such as yours.
    What he was trying to say was that when these type of chipsets are
    advertised it doesn't mean that they are available. Manufacturers
    often produce a product and "float" the idea in the electronics data
    sheets to see what interest they get from OEM's. If they don't get the
    right response they don't produce the product until someone takes the
    bait and orders at leat 100,000 of them. I've been caught out like
    that in the past.
  5. Mochuelo
    Mochuelo Guest
    You can buy the ST7538 from www.digikey.com (497-4316-1-ND) for 10.8
    USD (qty 1) /.../ 6.86 USD (qty 500). They have 2035 units in stock.
    Best,
