Subject: Re: Need a little help building a 12 volt timer
[email protected]
Date: 10/11/2004 3:23 PM Central Daylight Time
Message-id: <
[email protected]>
Hi Rich,
Excellent advice. When stuff goes past the one minute marker these 4000
logic choices are clearly better than some RC combination on a one-shot.
Regards, Joerg
Joerg speaks truth -- the longer the time delay, the more chance of something
coming around to mess timing up like electrical noise from the relay you're
driving, power supply hash, you name it.
A lot of time delay relays built in the 1970s and 1980s were based on the 4060,
mostly because if noise from the relay caused the oscillator to add a count,
well, there are always 16383 other counts to keep timing stable. These relays
were never specified at better than 1% repetitive anyway.
Here's something that should work for you (view in fixed font or M$ Notepad):
VCCVCC
| |10K VCC VCC VCC VCC
VCC 270K| || | | | | |
+ | || |.----o-----o----. | |
| '-''-'| 8 4 | | C|
.-------o---------. | | | | 1N4002- C|RY1
| 16 | | | | | ^ C|
| |.001uF | | | | | |
| 3o---||--|--o-o2 3o------. '---o
| 4060 | || | | | | |
.-o8 | | | 555 | | |
| | | o----o6 | | |
| | | | | | 1K| | |
| | 11 10 9 | o----o7 | | | |
| '-o------o------o-' | | | '-' |
| | | | 10uF| | | | |/
| .-. .-. | --- | | o-----|2N3904
| | | | | --- --- | 1 5 | | |>
| | | 50K| | --- | '----o-----o----' .-. |
| '-' '-' |0.1uF | | 1K| | |
| |220K | | === === | | |
| | | | GND GND '-' |
| '------o------' | |
GND GND GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta
www.tech-chat.de
You're using the built-in oscillator on the 4060 to generate a 91 Hz clock with
the .1uF cap, the 50K resistor, and the 220K resistor. That gets rolled around
in the divide-by-2^14 ripple counter in the 4060, coming out as 1/180 Hz (do
the math). That means you get a NGT to trigger the 555 through the .001uF cap
with the 10K pullup once every 3 minutes. The values of the 555 are set for a
3 second pulse, which drives the relay through the transistor. Try to find a
relay with a coil that needs 100mA or less.
A few notes here. For the 50K resistor in the 4060, you might want to use a
39K resistor and a 25K pot. For the 270K resistor on the 555, you might want
to use a 220K resistor and a 100K pot. Use a CMOS 555 if you can -- leakage
currents on a regular 555 might cause you problems. But the main caveat is,
don't use electrolytics for either cap, especially the 555. Use a tantalum if
you can -- it will generally have lower leakage current. Also, keep your
circuit board clean and out of high humidity environments.
I hope this has been of use. Questions of this type generally receive a better
response on sci.electronics.basics.
Good luck with your project
Chris
