Need a 1.8V supply
Discussion in 'Power Electronics' started by Rajinder, Mar 25, 2019.
  1. Rajinder
    Rajinder
    402
    7
    Jan 30, 2016
    What is the best way to achieve a 1.8V supply? Can this be done with transistors only? I have 3V3 input need 5mA output.
    Thanks.
  2. dave9
    dave9
    773
    171
    Mar 5, 2017
    It would be easiest to get a precise output by just using an LDO, low dropout regulator. An old/common choice would be an LM1084.
    http://www.ti.com/lit/ds/symlink/lm1084.pdf
    It has a typical minimum load of 5mA and max of 10mA, so if it isn't stable at your 5mA load you might want to put a resistor between positive output and ground to give it 5mA more load, 10mA total... in this case the loss is negligible unless the device needs to run days at a time from small batteries.
    Ian likes this.
Similar Threads
Loading...
