Need 3 inch (76mm)/1 Watt/8 Ohm speaker replacement
Discussion in 'Electronic Repair' started by D-Man, Sep 27, 2007.
  1. D-Man
    D-Man Guest
    I have this problem, I live in the UK. I need a 3 inch, 1 watt 8 ohm
    speaker (may also be called 76mm in terms of size).
    I tried Maplins and RS, both no longer stock the product.
    Help anyone? I did find a place called ABCelectronics in the US
    stocking the speaker, however this is no good. Again, looking for the
    product in the UK.
  2. Ron(UK)
    Ron(UK) Guest
    CPC in Preston almost certainly stock what you need
    Ron(UK)
  3. Baron
    Baron Guest
    D-Man inscribed thus:
    Depending where you are I may be able to help.
  4. Baron
    Baron Guest
    Baron inscribed thus:
    I am in the UK, and have some of these.
