NEC Projector clock reset
Discussion in 'Electronic Repair' started by Russ Peck, Jan 6, 2007.
  1. Russ Peck
    Russ Peck Guest
    Any ideas to reset a lamp clock for a NEC MT1056 projector. Got it on eBay
    with no remote and it would seem no way to reset the lamp clock without it.
    Russ
  2. Tim Schwartz
    Tim Schwartz Guest
    Russ,
    I don't know your model of projector, but from the one I just had to
    change in my Father's NEC, I would not reset the time without replacing
    the bulb. When I inspected the old lamp, The reflector coating was
    beginning to separate from the glass, and looked 'wrinkly'. These bulbs
    contain mercury, so if you run it until it blows and it shatters,you can
    basically throw out the projector. Also, if the bulb fails, it might
    take its power supply with it.
    However, ant least on the LT-240K, you still have to reset the lamp
    time with the on screen displays, which will require the remote if the
    unit does not have redundant controls on it.
    Regards,
    Tim Schwartz
    Bristol Electronics
    P.S. Yes, I know all to well that these lamps are expensive.
  3. Mike
    Mike Guest
    I had a boxlight CP-7T that the same thing happened. lamp exploaded in it.
    and the ballast was NLA.
    So, i just rebuilt the ballast. the transformer was ok, just the H-bridge
    that drove it was shorted. replaced it, along with the fusable resistors,
    worked like a brand new one :)
  4. Russ Peck
    Russ Peck Guest
    Thanks Tim,
    I did replace the lamp with a new one. Left that out of my post.
  5. Ray Carlsen
    Ray Carlsen Guest
    Russ,
    I don't have info for that model, but earlier and later models as follows:
    For NEC MT1040 & 1045, if the old lamp time exceeded max hours, the projector
    will not come on with a new lamp installed and the projector remains in
    "standby" mode. In that mode, press and hold OFF or HELP button for 10 seconds
    minimum. The STATUS indicator should go out and the projector should turn on
    normally with the lamp counter reset to zero. Nodels MT1060 and later have an
    EEPROM on the lamp housing that will not allow more than the max hours. Changing
    the lamp automatically resets the counter. Yours might respond to the earlier
    command... worth a try.
    Ray
