NEC PJ3715EN
Discussion in 'Electronic Repair' started by [email protected], May 2, 2007.
  1. Guest
    HI I have a NEC rear projection NEC PJ3715EN YEAR IS 1996 TV and
    just want to get advice on troubleshooting it....there was a black bar
    on the bottom whacking the TV from behind fixed it so I suspect a bad
    solder joints. Also the color is not right I just want steps to
    trouble shoot I have experience with electronics thanks
    db
  2. Meat Plow
    Meat Plow Guest
    You've already trouble shot the vertical. No trouble shooting the color
    other than making sure the lenses on the crts are clean and the fluid
    inside is clear and the mirror is clean. Maybe get a service manual and
    tweak the video settings. 11 years on a projector is getting up there in
    years so you also have to consider that one or more of the crts maybe be
    weak.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. hr(bob)
    hr(bob) Guest
    Is Whacking your primary trouble-shooting method? <G>
    H. R. (Bob) Hofmann
  4. Sofie
    Sofie Guest
    deliper:
    I am certain that whacking won't "help" the problem with the color
    either....
    If you already suspect bad solder joints what troubleshooting advice do you
    want?? Your method of troubleshooting is already troublesome.
    Fix the suspect solder joints as you surmised and see if that solves the
    problem, but don't keep whacking the television or you will have bigger and
    more expensive problems.
    You may want to go to the website for this newsgroup at
    http://www.repairfaq.org/
    there, with some search time, you will find a wealth of proper
    troubleshooting information that will help you to repair your television.
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
