NEC MT800G repair help
Discussion in 'Electronic Repair' started by Janne, Nov 16, 2004.
  1. Janne
    Janne Guest
    Hi
    I have problem with my NEC MT800G LCD projector, the picture are
    "distorted". No fault with the convergence, it seems to be a problem
    with the "RGB" signal to the LCD panels. The symptom is (I feed with a
    grid pattern) that some of the lines (vertical) are ok but some are
    the colors is out of "focus" (like convergence fault). If I change the
    width of the picture the fault moves to another line.
    I think that it could some problem with the video board (SAA7110A +
    7192A).
    Can somebody help me out with this or know where I can find a
    schematic?
