NEC FS6390
Discussion in 'Hobby Electronics' started by Newsboy, Nov 21, 2004.
  1. Newsboy
    Newsboy Guest
    Hi All,
    I've inherited a blown FS 6390 NEC television off the in-laws, I can
    tell a few of you will delete now ! If not, I have popped the cover and
    traced the power, 240v in and the fuse is ok, found a blown area in the hot
    side of the circuit board, but the main problem looks like an item attached
    to a large heatsink that has blown, I've been having a bit of a google and
    can't find too much, can anyone help with a site that may have circuit
    diagrams or info ? The blown off part is labelled STR S6708 SK5N18. I found
    one place in the states that sells them in bulk but they don't name it ! I
    have some digital pix of the areas if anyone would like to volunteer to
    advise remotely ! The part has many legs soldered to the board, so that begs
    the question, how the hell do you remove it ?
    Any help or pointers greatly received as having read the TV serviceman
    section in EA, I know they are a trying mistress.
    Steve.
  2. Phil Allison
    Phil Allison Guest
    "Newsboy"
    ** WES Components in Ashfield sell them - for circa $20 each inc.
    Phone (02 ) 9797 9866 and pledge your plastic.
    Lots of Luck !!
    ......... Phil
  3. Newsboy
    Newsboy Guest
    Okay, I've answered one of my own questions ! De-soldering pumps and braid !
  4. Phil Allison
    Phil Allison Guest
    "Newsboy"
    ** This lad is on the threshold of a ** STEEP * learning curve ....
    ............. Phil
  5. Newsboy
    Newsboy Guest
    Thanks Phil, what is the part actually ? a resistor or something ? I 'm
    proud to say that I know which end of a soldering iron to hold !
  6. Phil Allison
    Phil Allison Guest
    "Newsboy"
    ** The number alone gives little clue as to what it is - for that you need
    a schematic or the set to inspect.
    But if you need one - you now know where to go.
    ............ Phil
  7. Phil Allison
    Phil Allison Guest
    "Ken Taylor"
    ** Spoilsport !!!
    .......... Phil
  8. Ken Taylor
    Ken Taylor Guest
    Steve, it's a switching regulator. Given that you mistook it for maybe a
    resistor, you probably don't want to hear that it's probably going to blow
    again when you replace it. Watch out for big voltages (and big bangs).
    Ken
  9. Ken Taylor
    Ken Taylor Guest
    I'm reminded of the old expression about "shooting ducks on the water"....
    it really isn't sport, Phil. :)
    Ken
  10. Newsboy
    Newsboy Guest
    Thank you ! I'm a network technician, so I'm used to seeing the magic smoke
    escape from equipment from time to time ! I also have a very healthy respect
    for 240volts and also for capacitors !
    Steve.
  11. mo
    mo Guest
    Too much spare time on your hands Bro?
  12. Franc Zabkar
    Franc Zabkar Guest
    Given that you can't recognise the difference between an IC and a
    resistor, I'm wondering what a capacitor looks like to you. ;-)
    - Franc Zabkar
