NEC FS6390 TV question
Discussion in 'Hobby Electronics' started by AB, Sep 22, 2006.
  1. AB
    AB Guest
    Hi Gents,
    I have a NEC FS6390 TV ( about 10 years old ) which has died in a big way.
    There is an IC , a STRS6708 , a 9 pin device on a big heatsink which is
    blown to bits. Nothing else looks damaged , but I assume there are other
    blown components around it.
    Can anyone suggest if it's worth getting repaired and around how much it
    would be ?
    Cheers
    Andrew
  2. Phil Allison
    Phil Allison Guest
    "AB"
    ** Well past its normal use by date.
    ** Yep - no.
    K-mart are now selling Magnavox brand 68cm, AV stereo TVs for $198 with 2
    year full warranty.
    ........ Phil
  3. AB
    AB Guest
    Thanks.
    Yeh I suppose I've had a good run out of it.
    Well for $198 for a newie its not worth repairing huh.....
  4. Guest
    If you would like to save some money and prevent a tv turning into
    landfill,
    I believe it is worth repairing.
    I have just repaired a FS6390 for a customer.
    It only needed a few capacitors, one transistor and a zener.
    The IC exploding is not unusual. As well as the chip, I could tell you
    which capacitors,
    resistors, zener and transistor may need replacing too.
    I think all the faults in the FS6390 I have seen have been in the power
    supply and are
    quite a routine repair.
    Russell.
